Suspension Questions
Old Oct 13, 2011 | 06:24 PM
nick86z28's Avatar
Car: 86 Camaro Z28
Engine: 355
Axle/Gears: 3.27 9 bolt
Anyone Who Dropped a 454 in a third gen have a problem with the stock suspension or did you have to get better springs?
Old Oct 13, 2011 | 07:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Suspension Questions
the added weight would require a heavier spring and good shocks to prevent the car from bottoming out. that said, im sure you can drop a 454 into a stock v8 3rd gen and drive it, and im sure its been done.
Old Oct 13, 2011 | 09:33 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I would also consider SFCs a must for an engine that large...unless you want a 3000 lb coil spring.
Old Oct 13, 2011 | 10:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on a lot of things. A BBC with aluminum heads and intake is about the same weight as a factory iron head SBC. Iron heads compared to aluminum add about 70 pounds to the engine. Cast factory intake about another 30 pounds. On average, a BBC is only 100-150 pounds heavier than a SBC. Ditch the heavy cast iron manifolds which you won't be able to use anyway for some headers for less weight.
For street use, I wouldn't recommend using V6 springs. Some heavy spring rate IROC or WS6 springs will do fine or any aftermarket factory replacement spring.
Have someone sit on the hood of your car. How far lower does it sit? That's what a BBC would normally do.
lt1z350
Aug 28, 2015 05:57 AM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
