Powersteering box leak on bottom? removal?
Old Oct 31, 2011 | 09:48 PM
joeyspagz's Avatar
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
i know this is a third gen site but i know someone could help. i have a 80 camaro z28 the power steering doesn't work, not the pump but the part where the steering column goes into leaks on the bottom of it. so how do i remove it? and is it fixable? thanks!
Old Nov 2, 2011 | 08:13 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Powersteering box leak on bottom? removal?
Is it leaking above where the pitman arm attaches to the box? If so you need to remove the pitman arm, then pull out the snap ring that holds the two seals in. Then start the car and turn the wheel all the way in one direction. The seals will blow out. Then, buy pitman shaft seal kit at your local store and put the new seals back in and reassemble everything.
Old Nov 4, 2011 | 10:03 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
cant tell where its leaking from but thats probably where the leak is. how could i get the whole thing out of the steering column?
Old Nov 5, 2011 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by joeyspagz
i know this is a third gen site but....
Because TGO is dedicated to thirdgens, you might try the following site for information more specific to your needs.
http://www.camaroz28.com/
JamesC
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
