power steering leak wont stop
Old Nov 30, 2011 | 06:32 PM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
hey guys
pulling my hair out over here
ta started to leak power steering fluid out of the hard line going in to the top of the steering box.
undid the pipe and put a new o-ring on and still leaking done this a number of times with a number of different o-rings bigger smaller and so on.
still leaking spent 2 days on it now really getting to me. im i doing somthing wrong??? is there more to it then what i am seeing?
thanks guys
bad
Old Dec 1, 2011 | 03:21 PM
UMI Sales's Avatar
Re: power steering leak wont stop
Hey btbb. Can you install the fitting smoothly with your fingers (i.e. is it crossthreaded at all)? Is it the stock steering box?
That o-ring size is pretty critical both for proper sealing. The first time you tried a new o-ring was it automotive specific for that exact application?
ramey
Old Dec 1, 2011 | 05:33 PM
Car: 89 gta
hey thanks for the reply.
thankfully i got the problem sorted later on today. after trying a number o orings even 2 at a time i found the problem. there was a small crack around the end of the pipe under the pipe fitting. quick solder and job done. going to order a new pipe. dont think it will last for ever.
thanks again
bad
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
