Constant shaking?
Old Nov 30, 2011 | 08:46 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Constant shaking?
THis started maybe a month ago, maybe not that long. It's a constant shaking as if my right rear wheel is not a perfect circle. (if that helps you understand what I mean by shaking.) I figured that maybe a wheel weight fell off, but they all appear to be on there. It feels like it's getting worse, and it's annoying. Could it be the brakes at all? I just replaced my front pads, and I might be doing the rear shoes tomorrow...any ideas? Any questions? I might not have explained it too well...
Old Nov 30, 2011 | 08:56 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Constant shaking?
If you don't find anything broken or loose, try driving the car with your spare in place of the wheel you think is causing the problem. If it goes away, you have your answer.
Old Nov 30, 2011 | 08:57 PM
chevydrvr's Avatar
That is a good idea, i'll have to try that after I do the brakes.
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
did you loan your car to a "friend"? maybe they found a curb they couldn't resist? ge that wheel spin balanced and aks them to check it out!
Old Nov 30, 2011 | 09:07 PM
chevydrvr's Avatar
If the spare doesn't let me know, I'll see about getting them all balanced.
Old Nov 30, 2011 | 09:46 PM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Yeah sounds like tire. Hope the spare works out. It would be a nice simple problem solved without paying out the ****! I had that happen 2 days ago.....rear end was shaking....It really felt like the drivers side rear so we pulled the tire off and it was concaved in....right in the middle of the tread....popped another tire from one of our others on and drove smooth.
Old Dec 4, 2011 | 08:41 PM
chevydrvr's Avatar
I found out it was the wheel being off balance, I assume, so i will see if I can get it rebalanced...
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
88rscamar0
Sep 23, 2015 09:08 PM
Amillionoh7
Sep 5, 2015 11:44 PM
