Cutting Camaro Springs Safe Or Not?
Car: 1986 Camaro Sport Coupe
Transmission: 700-R4
so i have a SC and it rides pretty high compared to the iroc & the rs and the prices ive seen on lowering springs are pretty high and i heard you can cut them so is it safe any pros and cons? thanks
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Cutting Camaro Springs Safe Or Not?
I cut a full coil off my front and rears. I left the rear isolators in but the front ones were toast.
I cut them with a band saw.
I'm on my phone so I can't post pics here. But, I have pics in my vert build thread in the body forum.
I love how it looks, but I'm going to remove the rear isolators.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its safe and common. Trick is to try to not add a lot of heat into the spring, so cut with a cut off wheel, hack saw, recip saw, band saw ect. Dont use a torch
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
on the front cut half a coil first and try it.i cut a full coil and had to replace the springs because the front end was dragging on everything.
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I cut a full coil from front and rear....no bottoming out YET been 3 years
db057
Aug 11, 2015 10:11 PM
TA8487
Aug 11, 2015 09:02 PM
