umi adjustable panhard rod
Old Jan 9, 2012 | 03:35 PM
WilliamSilver's Avatar
Tried to install my new panhard bar but the bolts are stuck.
Got the nuts off with ease. And the bolts rotate but I can't pull them out. Any suggestions
Old Jan 9, 2012 | 03:40 PM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
Re: umi adjustable panhard rod
did you try a hammer
Old Jan 9, 2012 | 03:41 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
i'd try wd-40 and a hammer, just work at it, unless its welded it'll come out.
Old Jan 9, 2012 | 03:51 PM
Tried both a hammer and pb blaster. I ordered bolts from sphon I guess ill wait till next week and cut them
Old Jan 9, 2012 | 05:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The bolts tend to rust and sieze to the steel sleeve in the bushing. Sometimes a BFH will break them loose, sometimes not.
Old Jan 9, 2012 | 05:37 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
And when you put it back together coat the bolts w anti-sieze..
Old Jan 9, 2012 | 08:20 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
The shaft of the bolt is probably pitted with rust preventing it from sliding out smoothly. Be careful you don't damage the hole on the receiving end. You don't really care about what you do to the old panhard bar to get it off.
Old Jan 9, 2012 | 09:25 PM
thanks for all the responses. Im waiting for the bolts and cutting those bastards off. a BFH had no effect haha
Old Jan 9, 2012 | 09:31 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
mine did the same thing, use a breaker bar and then have a friend take a punch and a bug hammer and hit it from the back as you turn the nut.
Old Jan 10, 2012 | 04:49 PM
83 Crossfire TA's Avatar
I had one rust to the sleeve in the bushing, you could turn the bolt, the sleeve would turn with it but no dice on getting it out. Usually leaves you with 2 choices: burn it out with a torch or take an angle grinder and cut the bushing out...
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Antips16
Oct 30, 2015 06:42 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
