Lowering the firebird
Old Jan 13, 2012 | 04:13 PM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
I purchased the Eibach sportline spring kit, lowering my car 1.6" in front and 1.3" in back (minus the difference from the wear on the old factory springs). I already got the adjustable panhard bar, and I plan to make my own Relocation brackets for the lower control arms (LCARBS), but my biggest question is concerning the front of the car.
Will I need the caster/Camber plates to lower the front 1.6"? Or will I be able to get away with aligning it with the factory style mounts?
Also, If anyone has a template for the LCARBS, that would save me A LOT of time!!
Thanks!
Old Jan 13, 2012 | 05:21 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Lowering the firebird
Your front end should align just fine...Mine did & I'm lower than that. And LCARBs are not required after lowering.
Old Jan 13, 2012 | 07:02 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I was under the impression that if the car is lowered enough where the rear of the LCA's were higher, (over horizontal, which a set of Pro Kits will probably do), than the fronts, LCARBS were a good addition as rear traction would be adversely affected.
Old Jan 13, 2012 | 07:09 PM
Car: GTA
Originally Posted by watajob
..... LCARBS were a good addition as rear traction would be adversely affected.
Depends on your right foot. I don't drag race so it is of no concern for me, not on the road.
Drop your car & then decide if you need the extra traction. If so? Put LCARBs on/get better or wider tires. LCARBs are certainly not required items. I'm certainly lower than the 1.3" you say you'll get & mine doesn't bother me any.
Old Jan 13, 2012 | 10:15 PM
potterc32's Avatar
I guess it'll make it easier to show off in a parking lot, but tougher to show off on the highway!!
But I got a great simple template for the LCARBS just in case.
What do you think about the adjustable torque arm? Is that necessary lowering the rear only 1.3" (of course that's just what they say, may not even get any lower than an inch, because my tires are an inch taller than factory, which would raise my axle a half inch)
I think I'm sold on just aligning it with the factory strut mounts, really don't want to shell out too much money if I don't need to right now.
Old Jan 13, 2012 | 10:19 PM
potterc32's Avatar
now that I think about it... would tire size even make a difference with the instant center of the LCA's?
will taller tires make your tires want to hop because it makes the LCA point downwards? If I'm thinking correctly, would'nt you need LCARBS if you put on some HUGE tires? (hypethetically speaking, most people with that big of tire will have other mods I'm sure)
Old Jan 13, 2012 | 10:48 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
adjustable torque arm is not neccesary for a street car, it will help you reset the pinion angle after you lower the car but it will barely affect the car, all you need is an adjustable panhard bar and the lcarb if you need them, but drive the car first, then decide.
and read the stickied threads, they have all this info in them.
Old Jan 13, 2012 | 11:02 PM
Car: GTA
...But I got a great simple template for the LCARBS just in case...
If your referring to that hand drawn pdf file sketch posted in another thread, I'd call it FAR from great. Hell, I'd hardly call it useable, because I've seen a MUCH MUCH better layout done in MSPaint.
Old Jan 13, 2012 | 11:45 PM
potterc32's Avatar
I wasn't looking at the drawing... I'm looking at dimensions and measurements. he told me exactly where the center of the holes are, and general dimensions of the width and whatnot.
I printed it out and it's not even to scale, but like I said, I can create my own as long as I have an idea of where the holes are supposed to be.
Old Jan 14, 2012 | 03:37 PM
potterc32's Avatar
Here is my edit of that drawing, but using 3/16" steel. And I did not include a mounting point that goes to the (strut mount I believe, could be mistaken). the top part of the one view was cut off due to the size of the paper I'm using with my CAD program.
Let me know what ya think!
Old Jan 14, 2012 | 04:21 PM
Car: GTA
Much better, although it has some missing measurements.
Old Jan 14, 2012 | 05:20 PM
potterc32's Avatar
I realized that when I took a second look at them. I ended up breaking it down into 3 separate drafts, 1 of them to tell exactly where and what size the holes are, and 2 to show just the outlines and their measurements. Putting it all on one piece of paper is outrageous, even when I eliminate the unnecessary yet beneficial measurements.
Using 3/16 isn't overkill is it?
Old Jan 14, 2012 | 06:22 PM
Car: GTA
My Spohn LCARB mounts main walls were built from 3/8". And an additional 3/16" inner wall added under the stock mount where the LCAs mount, for a 9/16" total thickness in the lower section.
Old Jan 14, 2012 | 08:52 PM
potterc32's Avatar
Holy crap... that's pretty heavy duty.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
Dialed_In
Aug 20, 2015 01:45 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
