rubber spacers on top of front coil springs
Old Jan 29, 2012 | 11:05 AM
sheldon87cam's Avatar
Axle/Gears: 373
hi guys i`m starting reassembly of my 87 camaro after afull nut and bolt restoration . i am getting ready to take it off the rotessorie and about to put the front coil spring in and noticed that i have misplaced the rubber insolators that were on top of the front coil springs , i have went ahaead and installed the springs so i could continue to assemble front end so i can get car back on the ground , my question is will it hurt to leave these rubbers out as i really do not want to have to take front suspension apart again , it is not the work i just do not want to risk scratching anything thanks sheldon
Old Jan 29, 2012 | 11:36 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: rubber spacers on top of front coil springs
They are just there as a possible noise insolater. You will.be ok without them
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
