rusty strut tower and wheel hop w/pics
Old Feb 6, 2012 | 07:11 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
experiencing a wheel hop or bottoming out feeling on the right front side. have not driven car much last year or so but it feels abnormal and not something i can trace to wore or loose suspension. car has subframe connectors, tubuar k member & A arms, umi camber plates, umi strut brace, wonder bar, lowering spring, new struts. so it's super stiff, now question is would rusty towers flex causing my problem, it's the only explanation i can think of. pics
now i i've seen worse but it that rust bad enough??
Old Feb 6, 2012 | 07:17 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: rusty strut tower and wheel hop w/pics
If they are thin then yes. It may be strong where it's bolted into the brace but that pressure will move to the next weakest point. Also is that a hole off to the right where rust has eaten through? But the rust You are talking about appears to be surface and not that bad.
Old Feb 6, 2012 | 07:49 PM
godreject's Avatar
Yea i know rust isn't that but thats why im confused. the hole is not rust, the bracket is just not centered. heres another rust pic across the firewall, this one is worse, but i figured the subframes would prevent flex and make this rust a non issue.
J-money
Jan 4, 2019 09:45 AM
rb85TA
26
Sep 14, 2015 10:29 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
89 formula TPI
Sep 8, 2015 08:00 PM
SG91camaro
Sep 5, 2015 10:27 PM
