WS-6 Question
Car: 91 Firebird
Axle/Gears: 3.08
WS-6 Question
Hello all, I have finally just come back into th FBODY world after an 8 year or so absence. I just bought a 91 formula, 305 5 speed w/110k. Going to pick it up next weekend and I cant wait, missed these cars. My question, I have a friend with the ws6 suspension parts (just springs and sway bars, correct?) for sale, really cheap, and I was wondering if you guys thought they would be a better choice then picking up aftermarket stuff. I will not be lowering the car either. Thank you all in advance for the opinions/suggestions! Great to be back
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
Re: WS-6 Question
if they're indeed ws6 parts then they should be MUCH cheaper than aftermarket parts, not sure about comparison between them but my bet would be that there is not much difference at all. go for the parts, save yourself a couple hundred.
Re: WS-6 Question
And, the springs are already just as wore out as yours. (most likely) 50% chance they're even worse.
Pass.
Pass.
Car: 91 Firebird
Axle/Gears: 3.08
Engine: 4++,350 & 305 CIs
Re: WS-6 Question
ALL FORMULAs came standard with WS6 stuff, from 87-92 and the base motor to the 350.
look in the console or the locked part in your hatch and look at your RPO codes. it will have WS6 if its truely a formy.
Buy/replace any worn steering parts (ider arm is usually the worst), subframe connectors, Bilstein shocks n struts wonder bar, dub adjst pan hard bar and maybe box your rear lower control arms.
step 7, enjoy.
step 7, enjoy.
Transmission: Pro-built 700R4
Re: WS-6 Question
step 7, enjoy.
step 7, enjoy.
Formulas & GTAs come with the WS6 from the factory. Trending Topics
Car: 91 Firebird
Axle/Gears: 3.08
Re: WS-6 Question
So I'm picking the car up finally, and I don't see the ws6 rpo code. The vin said formula.. ?!
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: WS-6 Question
are you sure I just bought a sway bar from a 87 GTA and it was not the WS6 rear was the same it was not the 24mm like on the WS6
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: WS-6 Question
a base firebird and a formula will come up the same if you search by vin. If the car does not have ws6, its not a formy. People CONSTANTLY think base firebirds are formulas if they have the 305 tbi engine. Thats most likely what you are buying, a base firebird with the 305 tbi engine
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: WS-6 Question
After all these years, you can't be certain that nothing has changed (like WS6 parts ending up on another car) unless it is a 1-owner car & he can verify that. Although with the # of bad sellers out there, nothing short of measuring the sway bars & reading tags on the springs? You can't be 100% certain one way or another.
