Wonderbar question
Old Mar 4, 2012 | 06:19 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Wonderbar question
Has anyone seen this? The bottom hose fitting on the radiator in my son's '87 V-6 Camaro is angled down so the radiator hose extends down into the area where the wonderbar should go. The bottom fitting on the radiator in my V-8 Firebird goes straight out and doesn't cause a problem. Anyone have a suggestion? Don't know that I can just change the hose, fitting still points down. Can't shim the wonderbar down lower, wouldn't do what it is supposed to.
Old Mar 4, 2012 | 07:13 PM
Tonygxp's Avatar
Car: '89 GTA Brilliant Red
Re: Wonderbar question
sounds like you need to change out the V6 radiator?
Old Mar 4, 2012 | 07:41 PM
Since the wonderbar didn't come on any 6-cyl cars, it was never an issue... there's no "supposed to" available here... you just gotta do whatever it takes.
That's part of why we call it "modifying" cars (and parts), as opposed to merely adding previously unistalled options...
Old Mar 4, 2012 | 07:58 PM
Hal87's Avatar
Thanks guys, that's what I thought too, just figured I would see if someone had come up with an easier fix
Old Mar 4, 2012 | 08:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i was able to put a wonderbar on my 92 v6 car, only issue was the lower hose has a wide sheetmetal support that i had to roll up a bit for clearance. No issues with the radiator itself.
Old Mar 5, 2012 | 10:07 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
My version of steering brace will work fine in your V6 application. The center bar is located further toward the rear of the car than on other aftermarket brands. The lower radiator hose is squeezed a bit into an oval shape by the center bar, bit the interior volume is unchanged so there is no restriction on flow.
Lon Salgren
Old Mar 5, 2012 | 10:48 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
The 3.1L V6 uses the same radiator as the V8 where the lower hose is on the passenger side, the 2.8 radiator is narrower and the lower hose comes out buy the steering box. 3.1L should be the 91 & 92 models, not sure about the 90 model year. I had no issues putting a stock wonderbar on my 92 V6.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
