PITMAN ARM??
Old Mar 8, 2012 | 02:56 PM
aroc256's Avatar
Car: 1988 firebird formula
Engine: 5.0 tbi
Transmission: 5spd std
Axle/Gears: stock
PITMAN ARM??
So my car seemed to be driving all over the place,bump steer and what not soo i take it to kaltire and they are telling me i need a pitman arm amung other things
HOWEVER all the part stores ive called (including the dealer), lordco and napa tell me they dont make it, and the dealer says its discontinued, AND both said this is typically a non wearing part
any one run into this problem b4??
Old Mar 8, 2012 | 03:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: PITMAN ARM??
The pitman is a non-wear item. It's generally only replaced if it's been damaged, say, in an accident. Perhaps the shop meant idler arm.
JamesC
Old Mar 8, 2012 | 03:03 PM
87350IROC's Avatar
Car: 87' IROC
Re: PITMAN ARM??
Pitman arm is not a wear item. Unless it is obviously damaged your problem lies elsewhere. Idler arm is a common problem on these cars.
Old Mar 8, 2012 | 03:06 PM
aroc256's Avatar
Engine: 5.0 tbi
Axle/Gears: stock
Re: PITMAN ARM??
i think they might be getting there parts mixed up then mabey?
Old Mar 8, 2012 | 03:37 PM
87350IROC's Avatar
Car: 87' IROC
Re: PITMAN ARM??
That is a good possibility. Not sure I want a shop working on my car that confuses the two though.
Old Mar 8, 2012 | 11:21 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: PITMAN ARM??
they probably meant the center link is worn out where it attaches to the pitman arm. which Kaltire did you take it to?
Old Apr 23, 2012 | 03:00 PM
Guest
Guest
Posts: n/a
Re: PITMAN ARM??
http://www.rockauto.com/catalog/moreinfo.php?pk=355468
http://www.rockauto.com/catalog/moreinfo.php?pk=201907
http://www.rockauto.com/catalog/moreinfo.php?pk=355319
These are the three Items you need replaced.
You may even have play in your rag joint or in your steering gear box, but mostly the box.
And you may even need new ball joints.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
