How to Adjust LCA and Panhard
Old Mar 31, 2012 | 01:14 PM
IrocEspo28's Avatar
Car: 1988 Camaro
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 373
I bought a single adjustable PHB and LCA with the rod ends to go on ford 9in, neither came with direction nor have any posted on the website. I have done research on the boards, but the info is not specific enough.
On PHB, it cant not be adjusted on car. So from what I understand after I make the measurements, I have to have someone push the body over to allign the bolt holes? is this correct?
On LCA, it cant not be adjusted on car either. How do I measure for the adjustment, as well as move the rearend front/back to make the allignment?
On a seperate subject, I was installing a new sway and noticed that the drivers side end link was completely blent. Why would this happen, secound is there an adjustment I need to make to prevent this from happening again?
Please use alot of detail if possible.
Thanks Guys
Old Apr 2, 2012 | 12:43 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: How to Adjust LCA and Panhard
I recently replaced my lower control arms to the adjustable ones also. I used my stock lower control arm as a template on a piece of wood and drilled out the two holes. used the bolts to hold one end in the wood and adjusted the other till I could get the second one perfectly lined up. Used the same pattern on both control arms and also put a longer bolt thru both control arms together just to double check that my drill didnt wander. Thats a easy starting point to go with.
The panhard bar I just used a longer bolt and adjusted it till it was the same length as stock and put it on. Then I taped a string with a washer on both sides of the wheel well and took the measurement from side to side. Adjust it till your centered and lock it down.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
