quick adjust PHB question
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I was wondering if I'm supposed to center the rear with the wheels in the air of try to do it with them on the ground, does it make a difference?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: quick adjust PHB question
either way will do the same thing. key is to have the suspension completely loaded
Car: 89 Formula 350
thanks guys, yeah I did it in the air unloaded. Then I put it on the ground and it was way off. So then I just adjusted it under load on the ground.
