stteering wheel flops around
Old Apr 4, 2012 | 09:41 PM
91camaroRS3.1's Avatar
Car: 86 T/A
Engine: 305c.i. carbed, highrise, compcam
Axle/Gears: idk..
ok, cars due for an inscpetion. but my steering wheel flops around like its nothing....three no turning play, it drives straight and dosnt wobble at any speeds, but stoped or driving the steergin wheel moves aorund freely, like it letraly can flop all over the place? the kid who has it before my rear ended someone btw. it had some play when i got the car, left right and up down. but then my tumbeler went. (airbag was deplyed in the accident) so while getting to the tumbeler i yanked out all the guts to the airbag. the BIG yellow ring and everything....i reassbeled the steering wheel without these parts and it flopped ALL over the damn place after that...was the big yellow ring some sort of guide also? did i breaks something? any ideas here guys? im lost. and know NOTHING about steering colmns....
Old Apr 4, 2012 | 09:43 PM
Car: 86 T/A
Axle/Gears: idk..
Re: stteering wheel flops around
oh anit also can go in and out..like a telescopic wheel which i KNOW it aint..lol..it is a tilt wheel though i know that. tilt still works fine too..
Old Apr 5, 2012 | 04:53 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Use the Stickies... Have you read through this one?
https://www.thirdgen.org/forums/susp...-steering.html
Old Apr 5, 2012 | 09:11 AM
Car: 86 T/A
Axle/Gears: idk..
i belive that is EXACTLY what i needed, lol sorry for not paying attention to the stickys i will do so in the future
thanks bud
-91camarors3.1
Old Apr 6, 2012 | 09:19 AM
Car: 86 T/A
Axle/Gears: idk..
ok so i went throught that and it didnt help...FML heres a video of whats going on.
http://youtu.be/xP4n7LqwDHo
and YES my tumbeler is rigged up lol it went and i didnt feel like bypassing vats so i put the key in there and start it with the old plyers haha. pay no attention to it
:b
Old Apr 7, 2012 | 09:56 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Can you be a little more specific, ie. is the wheel moving separately from the column or is it all moving together? Only thing I can think of is that the column nuts are loose(though your description sounds like its not this) or more likely, it sounds like your steering shaft is not securely attached. Go under the hood, find the steering box and start there looking for something loose or broken.
Old Apr 7, 2012 | 12:31 PM
Car: 86 T/A
Axle/Gears: idk..
sorry for the delay but i finaly figured it out. there is a bearing just below the spring that goes over the coulmn. turns out the steering whel post needs to be pulled out while the little coller needs to be banged into the bearing to compress it. then the spring needs to compress REALY far down to hold the thing in the bearing. the spring compress down to the second ring holds the thing in the bearing. so that was my problem. thanks guys.
THEY FIANLY GOT MY FAV. SMILEY BACK!!!! WOOHOO
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
