Name this Part Upper Front Control Arm?
Subscribe
Apr 14, 2012 | 04:06 PM
I have a 1960 Biscayne Wagon that was converted into an El Camino. It has a third gen sub frame married up to it.
Trying to order Energy Suspension Front Upper Control Arm poly bushings, but I only see the lowers which I already have. I am using 1990 Camaro in the search, does the 90 Camaro have upper control arms in the front?
Here is a picture, my guess is I am using the wrong name or year. Thanks for the help.
Reply 0
Apr 14, 2012 | 04:09 PM
Re: Name this Part Upper Front Control Arm?
Quote: does the 90 Camaro have upper control arms in the front?
No.
JamesC
Reply 0
Apr 14, 2012 | 04:35 PM
Interesting ... does any third gen Camaro have upper Control Arms? I was told it was a third gen camaro subframe?
Reply 0
Apr 14, 2012 | 05:06 PM
No
Reply 0
Apr 14, 2012 | 05:43 PM
If the subframe is from a camaro, most people use 2nd gen camaro subframes for those type of swaps.
Reply 0
Apr 14, 2012 | 06:11 PM
looks like I have a 74-79 camaro sub frame/upper control arms. Chevy used three different types of Upper Control arms from 70-81.
http://www.leverfamilysite.com/F_Bod..._of_Uppers.htm
The dead give away was the raised bumps on the upper control arm bushing closest to the radiator.
So it is a second gen, not third
Reply 0
Apr 14, 2012 | 06:13 PM
Quote: If the subframe is from a camaro, most people use 2nd gen camaro subframes for those type of swaps.
Thanks sir you were spot on!
Reply 0
Subscribe
