Rear air shocks?
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Rear air shocks?
Anyone know where to find air shocks for the rear? I got a killer deal on some Centerline auto/drags but the rear backspacing is off and I have some stickout. I chewed the tires up a little because of this.I have seen the drag bags for the back for like 90 bucks that go inside the coil springs I but don't know if they will achieve the same thing.I'm just looking to keep the fender off the tire.I have searched and searched,anyone?
And don't give me this
I already have a dozen times.
I already have a dozen times. Joined: Sep 2005
Re: Rear air shocks?
NO!!!!!!!
Before you even HALLUCINATE that that's a good idea, pull back your carpet and look at the top shock mount.
For LESS MONEY, you can fix it THE RIGHT WAY, which is, springs. Less work, too.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
