Front End Struts or Springs Bad?
Old Apr 17, 2012 | 01:33 PM
rtyler53's Avatar
I have a 1991 Z28 that I think the front struts and springs are both bad on and wanted to make sure. I go to do the "bounce" test that everybody talks about but my front end wont bounce at all! I weigh 200 pounds and put all my weight on it and it doesnt bounce whatsoever. Any suggestions? It looks like the front sits a little low, but hard to tell. I also dont know if the previous owner put any lower springs on them or not. Does make a thud sound when going over decent size bumps at a decent speeds.
Thanks in advance for any help.
Old Apr 17, 2012 | 02:02 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
Re: Front End Struts or Springs Bad?
You'll probably have to take a look at the struts to see if they are stock or not, same with the springs. If they are stock, I would imagine they would at least look a little worn by now. Springs, unless painted some other color will be pretty hard to tell what they are. Stock ones did have a little sticker on them with a code so you could possibly tell what springs you have, if the tags are still there. The factory struts in my 87 IROC were all black. If they have been replaced with aftermarket ones, they are usually labelled fairly well, or a different color.
Old Apr 19, 2012 | 10:39 AM
rtyler53's Avatar
I'm not as concerned whether they are stock or not, but more wondering if the actual springs are bad or not. I know it wont hurt to replace the struts and springs but I am wondering why there is no bounce in the front end if the struts are bad.
Old Apr 19, 2012 | 03:26 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
My car was the same way. All my weight pushing down and it would not move at all at any corner. I would say your springs are fine. The struts are harder to test. You may have to remove them to make sure they are fully charged. If they are leaking at all they need to be replaced.
Old Apr 19, 2012 | 03:32 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Could your control arm bushings be worn/seized? If they are it could make the suspension feel hard and bad at the same time.
Old Apr 19, 2012 | 03:54 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Yes all of the above, now let us know what you find.
Old Apr 19, 2012 | 05:38 PM
rtyler53's Avatar
I will be tearing it working the front end early next month after i get back from a business trip. I will keep you posted on what i find out, thanks for the suggestions.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
LittleFranks
Aug 20, 2015 03:55 PM
