Poly isolators an moog 5662 front coil springs
Old Apr 29, 2012 | 03:10 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so about 2 monthas ago i installed my moog front coil springs an poly energy suspension isolators i think the poly isolators are making the ride height way to high is ok to cut half a coil off the bottom of the spring to make the ride height lower
Old Apr 29, 2012 | 03:15 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Poly isolators an moog 5662 front coil springs
You can cut springs with a saw never with a torch. What kind of isolators were in it before?
Old Apr 29, 2012 | 03:24 PM
Engine: LR4 4.8
The stock cracked rubber ones they were totally dry rotted out
Old Apr 29, 2012 | 03:25 PM
Engine: LR4 4.8
How much of the spring should i cut though this is my foret time an i dont want to mess it up a pic of where to cut would be sweet
Old Apr 29, 2012 | 03:38 PM
Engine: LR4 4.8
Ok so both springs are out an now im looking at maybe cutting half of a coil off does this sound about right
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
TA8487
Aug 11, 2015 09:02 PM
