Racecraft Spindle Brake Brackets
Old May 1, 2012 | 09:07 PM
83 Crossfire TA's Avatar
Does anyone know if the same brake conversion brackets used with stock spindles will work with racecraft spindles? I'm just wondering about the offset needed to mount the brackets (bolt spacing and thickness)
I asked them and their fabricator and they weren't positive, I've tried calling flynbye, the ones listed on their site as making the adapter brackets for their spindles and got the guy's wife, she said to call back after 7pm to ask questions about their parts and I've never gotten an answer after 7. I can't seem to find any other contact information and according to their site they've lost their fabricator/machinist and are back-ordered right now.
I can easily make my own but was wondering about the dimensions
Old Jul 21, 2012 | 03:31 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: Racecraft Spindle Brake Brackets
I may be to late to help.
But yes the will work, direct from the stock to the RaceCraft.
Old Jul 23, 2012 | 03:53 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
are you sure about that? I dont know whether they will or not but you cannot put stock brakes on Racecraft spindles so I think there would be a problem here as well.
Old Jul 24, 2012 | 02:45 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
yes, my conversion brackets that I made for my stock spends went on with out modification.
and yes you CAN NOT put on stock brakes.
Old Jul 24, 2012 | 05:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
^what he said. Stock brakes will not work without a bracket designed to work with the stock caliper, which is available, but not a common piece to use here.
I remember back a few years there was talk that ed miller worked with racecraft during the design of these spindles and they were made to the same spec as a stock spindle in the snout/dust bolt hole locations so that a typical brake upgrade bracket could be used with these spindles.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Genopsyde
Nov 11, 2015 10:46 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
