A-arm question
Old May 3, 2012 | 12:47 PM
Jaboski's Avatar
Car: 91 Firebird
Axle/Gears: 3.08
A-arm question
So I bit the bullet and bought some UMI tubular's, my question is about the seat on the arm for spring. Is there a cushion or anything you guys use? Thank you!
Old May 3, 2012 | 01:10 PM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Re: A-arm question
I believe they are referred to as spring isolators. And, unless UMI supplies something, they are only used in the upper location.
Old May 3, 2012 | 01:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: A-arm question
Nothing on the bottom, and its only.on the top.for noise reduction
Old May 3, 2012 | 01:35 PM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Re: A-arm question
Speaking of those spring isolators, is there anywhere to get new ones? When I swapped my springs I looked at local part stores but they didn't have any. I reused my old ones but if I pull my springs out again I'd like to put new ones on, they aren't making noise but the old ones were a little deformed and well... old hehe
Old May 3, 2012 | 01:44 PM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Re: A-arm question
Spohn sells them...
http://www.spohn.net/shop/1982-1992-...Isolators.html
Old May 3, 2012 | 02:30 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: A-arm question
i grabbed the moog ones, but they're a universal type; just a big flat rubber washer. found my stock ones after installing the new springs on my car......doh!
Old May 3, 2012 | 03:19 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: A-arm question
Just put in the upper Moogs from rockauto. Don't forget that safety chain when messing with the springs!
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
