Eibach lowering Springs Instalation
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Im buying Eibach 1" Lowering Springs in the near future. Will these ride like stock setup, or will my ride quality be noticeably worse than it already is.
How long does it take to install these? since The car is my DD.
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
Re: Eibach lowering Springs Instalation
will not ride like stock....takes about 1/2 a day.
the ride is going to be much stiffer..you will feel more bumps in the road,
the up-side is the handling is SO much better..and that out weighs EVERYTHING else
Axle/Gears: 4.10
Ok thanks. Thats what I was thinking.
All I need is the springs, I don't need the adjustable panhard bar, etc. since I'm only lowering 1", right?
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
I'm running the pro kit on my dd and don't mind the stiff ride. I didn't originally have the adjustable bar but later switched to one. You will love the way it handles and looks compared to stock.
Axle/Gears: 4.10
gscz28, how much did you lower your. Your paint/wheel combo looks awsome. What size wheels are those?
sailtexas186548
Aug 26, 2015 03:32 PM
