Rear axle problem
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Rear axle problem
So today my brother in law noticed that the rear tire on the drivers side of the TransAm sticks out past the fender well while the passengers side tire is inside the fender well. I measured them and the drivers side is 3/4" outside the face of the fender well while the passengers side is 1 1/2" inside the face of the well. This car was rear ended before I got it, but I thought I had fixed that when I replaced the impact bar. It was bent in 1 3/4" in the center, even had to pull the back wall of the trunk out. Any ideas about the axle being offset? The body brace and track bar do not appear to be damaged. The fender well on the drivers side is 1 3/4" higher than the other side. Guess I need to get it on a frame machine.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Rear axle problem
If you get an adjustable panhard bar you can straight that out. IMO
I've thought about that, would like to know why it is that way before I start tweaking. Have to move it over an inch to be even, that seems a lot for the panhard bar.
Swap wheels & tires from side to side, see if the problem follows.
Look at the Panhard bar and see if it's bent.
Car: '83 Camaro Z28
Engine: "Just a little something"
Axle/Gears: 3:73
Does it pull? Id check the previous suggestions first. I believe the T/A's use different wheels front and back like the Irocs do. Make sure it does not have a front wheel on the back (it shouldnt make it stick out however it may make it look more dramatic if you have a wide wheel on one side and a narrow one on the other) If they are swapped it may be less of an adjustment. Shot in the dark but worth checking,
red90IROCls1
Aug 25, 2015 06:56 AM
