New On-Car Adjustable Poly/Poly LCA's From Founders Performance
Old Jun 27, 2012 | 06:31 PM
FoundersPerf's Avatar
Former Sponsor
We have finally released our on-car adjustable turnbuckle style lower control arms. A few of the key features that make ours different is on the short adjustment side we don't use a weld bung but rather we made a one piece tube with thread for less welding. Our turnbuckle is also the only one made using forged 4340 alloy steel, rolled threaded (not cut), and then heat treated to the same strength as a qa1 or fk xm series rod end for superior strength.
MADE IN THE USA!
Founders Performance On Car Adjustable Lower Control Arms Poly/Poly
1982-2002 Camaro or Firebird Adjustable Lower Control Arms
ONLY $142.65
Replace those weak, factory stamped lower control arms with Founders Performance hevy duty tubular on car adjustable arms. These are a direct bolt-on replacement that minimize wheel hop, improve cornering, lowers ET's and greatly help your track consistency. Founders Performance control arms are constructed from U.S. made DOM steel tubing 1.250” OD x 0.095” wall, 1045 steel threaded tube adaptors (stronger than chrome-moly), completely CNC machined and fully pulse welded for outstanding strength. Founders control arms also feature easy adjustment using a super high strength 4340 alloy steel turnbuckle that has been heat treated to the same strength as most QA1, FK, or Aurora alloy steel rod ends for superior strength over any other brand turnbuckle on the market. Founders also doesn't cut the threads like our competition but we choose to roll our threads just like rod ends and high quality arp hardware.
Control Arm Features:
1.25” x 0.095” DOM Steel Tubing.
1045 Steel Threaded Tube Adaptor (stronger than chrome-moly).
High Strength Chrome-Moly ¾” heat treated plated turnbuckle.
High Frequency Pulse Welded Construction with Rosette Welds on the Bung Side for Extra Strength.
CNC Machined bushings sleeves with Proper 12MM ID (not 1/2") for use with Factory Bolt.
Standard Red or Black Powder Coating for a Great Looking Long Lasting Finish.
Improves Responsiveness and Control.
MADE IN THE USA!
For questions on this item please email us directly at salesdept@foundersperformance.com.
Old Jun 27, 2012 | 11:27 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: New On-Car Adjustable Poly/Poly LCA's From Founders Performance
Wow, I'm thinking i'll have to get all my suspension parts from you for the TA. Do you offer rod ended offset LCA's?
I think we need a torque arm from you as well!
Old Jul 3, 2012 | 02:01 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
some subframe connectors would be nice as well
Old Jul 4, 2012 | 05:12 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I have the Founders LCAs and adjustable PHB. I'm very happy with the parts and prices. Founders do you guys have an ETA on an adjustable TQ arm?
Old Jul 6, 2012 | 06:28 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'd settle for a plain torque arm from them. I appreciate their pricing and support of this site. Group buy anyone?
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Jorlain
Oct 8, 2015 01:57 AM
greenyone
Sep 8, 2015 08:41 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
