questions on lowering
Old Jul 25, 2012 | 09:41 AM
makingPAIN's Avatar
Car: 1985 firebird
Engine: 350 .40 over
Transmission: 5 speed borg(NWC), ram clutch
Axle/Gears: ROTATING MERCURY DRIVE.
hello so here is my question.. i have a 1985 firebird and i have just installed the eibach pro kit 1 inch lower on all four corners, and i got this kit because i have read that if you take these cars down around two or more inchs you will have to change alot of parts(panhard bar lower control arms torque arm exc) to make everything work properly.back to what i was saying though is i got the 1 inch kit so if i wanted it lower, i will just cut i quarter coil at a time until im happy, so is what i heard true because i dont wanna get it down there and realize i have coil binding issues or worse!!!!!!!!!!!!!! thank you very much for your help
Old Jul 25, 2012 | 11:10 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: questions on lowering
You may end up needing a adjustable panard bar if the axle is too far from center after lowering. When its at the height you want, check the angle of the rear control arms with the car on the ground. They should be about level. If the are not, and the body side is significantly lower than the axle side, you would be in need of some relocation brackets for the control arm, "lcarb"'s.
You will never have a coil bind issues with any over the counter spring, you simply don't have enought suspension travel to compress the spring all the way.
Old Jul 25, 2012 | 11:28 AM
makingPAIN's Avatar
Car: 1985 firebird
hey thank you very much i was a little worried about that whole thing.. and as for front u think stock a arms and steering components will be fine with a 2 inch or so lower?? stock honey comb wheels and breaks. ball joints and swaybar and link kit are upgraded but i dont think any of that will affect this...
Old Jul 26, 2012 | 03:15 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
The only thing that will be affected by lowering only one inch would probly be your shocks/struts. It will put more tension on your stock ones. anything lower than an Inch you would probly have to worry about lcarbs and panhards and such as 86TA mentioned also new shocks/struts to match your springs or adjustible ones. I also have the springs you have with kyb shocks/struts (stock replacement) and they are kinda on the rough side with the 1" drop anything lower and id have a feeling they wouldnt last very long.
Old Jul 26, 2012 | 03:56 PM
makingPAIN's Avatar
Car: 1985 firebird
yeah i have stock replacment struts and slightly upgraded rear shocks... i was figuring i will have to replace the struts alot sooner if i go lower... from stock it would be 2 inchs lower so its not like a slammed cholo 64 impala lol
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
