Sway Bar Questions
Old Aug 18, 2012 | 02:16 PM
j_huerta22's Avatar
Car: 1990 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Sway Bar Questions
I have a 1990 Camaro IROC-Z and the bushings needed to be replaced on both of the sway bars. I measured out the front and rear sway bars with a caliper and I got 36mm for the front and 24mm for the rear. When I went to the local parts store, they told me my car did not come with a 36mm sway bar (biggest was 34mm). I'm kind of baffled since I used a caliper to measure both and they were dead on 36mm and 24mm. Judging from the amount of wear on both the sway bars, I would assume that they were stock. Anyone else know something I don't and if so, where can I find a kit to replace the front bushings? Thanks!
Old Aug 18, 2012 | 02:34 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: Sway Bar Questions
I had the same issue with my 1988 Formula. NAPA has them but they are special order. Go to NAPA on line and I think you can order them directly.
Old Aug 18, 2012 | 03:14 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
You measured correctly, there were 36's on some of the cars. Spohn sells the rubber mounting bushings with new clamps that have a zerk fitting for greasing them. $39+shipping, not cheap unfortunately
Old Aug 18, 2012 | 04:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO, j.
The 36/24 combo is fairly common.
http://www.spohn.net/shop/1982-1992-...s-Accessories/
http://www.top-downsolutions.com/chassis-and-suspension
JamesC
Old Aug 18, 2012 | 04:17 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Talk to Lon @ TopDownSolutions. He helped me with this also, and he'll get them out to you quickly.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
