A arm bump stop options??
Old Sep 8, 2012 | 12:40 PM
BOTTLEDZ28's Avatar
Transmission: A4
I need to install new bump stops on the stock A arms on my car but I just bought a pair of new Koni yellows and was thinking of adding the progressive bump stops that go on the strut itself. Can anyone give me the pros and cons to using both styles? I am running Eibach Pros on my car. Spohn sells the progressive rate ones for $53. Ground control sells them for $25. The stock style can be had for under $15 if you look around and Energy Supension ones that go on the A arm can be had for $14 or so through Amazon. I just need to know which style is preferred and why the heck the Spohn ones are $53!!
Old Sep 9, 2012 | 11:32 AM
BOTTLEDZ28's Avatar
Transmission: A4
Re: A arm bump stop options??
I did some digging and it looks like I will be better off with the Koni shaft mounted stops but they offer a few different kinds. I have Eibach Pros with Koni yellows. Can anyone offer me any advice on which one will work better for me and my application up front?
My choices are the bottom 3 in the following link. I am no suspension expert so I hope someone can give me the footnotes to why Koni offers different styles. I will be using my car as a DD. No road course racing at all with it. I live in New England and the roads around here suck.
http://www.koniracing.com/bumpstops.cfm
Old Sep 9, 2012 | 03:13 PM
87350IROC's Avatar
Car: 87' IROC
I use the Ground Control soft versions on my Konis. They are awesome. Way better than the stock style bump stops. I would go with them over the Konis for cost alone.
morrow
Jan 13, 2024 12:29 PM
1992 Trans Am
May 10, 2023 07:19 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
