coil spring headache
Car: 1991 RS camaro
Engine: 5.7
Axle/Gears: peg leg for now
I got a 91 camaro RS with a v8. As I pulled in my drive I noticed the whole passenger side dropped lower than the drivers. I found the struts bad and figured that this would not cause the side to drop so I bought a set of Moog 5662 springs. After installing, the front is about 4 inches to high. Does anyone know what springs I need? I want to retain the factory ride height. Please any help would be appreciated.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: coil spring headache
Did you index the springs properly? That will make it sit way high. Also keep in mind your factory springs could have been worn out and sagging, making the car lower than it would have been stock.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
4" too high sounds like you just pulled the jack out & judged it by that & did drive the car any. Drive it around the bloc, or at least up & down the street, and then see how it sits.
Just dropping it down & not moving the car does not allow the suspension to settle.
Car: GTA
Car: GTA
5604 is WAY taller but way softer.
http://www.moog-suspension-parts.com...prod=MOOG-5406
Install Height 11.50"
Load 2249lbs
Spring Rate 321lbs
Free Height 18.66"
http://www.moog-suspension-parts.com...prod=MOOG-5662
Install Height 10.75"
Load 1690lbs
Spring Rate 748lbs
Free Height 13.0"
The 5662 that you used should not make the car sit higher. Check your spring index as mentioned above & roll the car as I already mentioned above. My bet is that 1 or the other (or both combined) will fix your height issue.
Load 2249lbs
Spring Rate 321lbs
Free Height 18.66"
Load 1690lbs
Spring Rate 748lbs
Free Height 13.0"
Car: 1991 RS camaro
Engine: 5.7
I actually drove the car around. Still sitting higher. I carried it to a mechanic to check things out, and he said that even if the springs haven't index, it would not cause the front to sit that much higher. The rep for Moog said that the 5604 spring rate would be correct. Info coming from everywhere, and I still pulled on what to do.
