rear end questions?
Old Oct 4, 2012 | 05:44 PM
sac92transam's Avatar
Car: 92 convertible t/a and 68 firedbird
Engine: 305/402
Transmission: 700r4/turbo400
rear end questions?
i have a 92 trans am that has drum brakes in the back and would like to go with a disc rear and posi. i found one at the junkyard that looks pretty good with disc and everything off of an 89 trans am would this work with no problem also with i have to change anything else to hook up the rear disc ?
or would it bolt up connect the brake likes and vamonos?
here is a pix of the rear end i found
Old Oct 4, 2012 | 06:22 PM
Re: rear end questions?
Basically, a direct bolt-up; no modifications required that I'm aware of.
Even the prop valve is the same, in your year, for both drum and disc; because the bydraulic requirements of the PBR calipers are about the same as drums.
Make sure they don't cut the parking brake cables; have them disconnect them from the "equalizer" thing in the tunnel, UNDAMAGED.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
