Steering column jammed
Old Oct 10, 2012 | 10:15 PM
redvalz28's Avatar
I am attempting to remove the steering column but the “D” coupling is jammed together. The intermediate shaft slides up and down freely and prohibits any force being applied to the column. Is the intermediate shaft supposed to move freely? Any suggestions would be appreciated!
Old Oct 11, 2012 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Steering column jammed
The intermediate shaft is held to the lower column by a bolt. Remove it (as I'm sure you have) and, if necessary, spread the coupler a bit. The shaft should not slide freely under normal circumstances. There are some pics and removal instructions in the following link that may be helpful:
https://www.thirdgen.org/forums/susp...ing-shaft.html
JamesC
Old Oct 11, 2012 | 10:24 AM
redvalz28's Avatar
Thank you, I have unbolted the column from the steering box. The intermediate shaft I believe is designed to collapse. The problem is that the intermediate shaft is damaged and slides up and down freely. This damage allows the intermediate shaft absorb any attempts to pull the two shafts apart. In my other Camaro the intermediate shaft does not slide freely. Any more suggestions would be appreciated.
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
