Rubber Spring Isolators: Top, Bottom Or Both?
Old Oct 19, 2012 | 10:19 AM
Sanjay's Avatar
I didn't note when I pulled my OEM springs out if the isolators we're at the top or bottom. I think they were at the top and nothing at the bottom.
I'm not even sure that's right cause the last time I lowered a third gen like 10 years ago I thought there was 1 at the top and 1 at the bottom.
Any help would be much appreciated. Lowering springs are going in tonight or tomorrow..
Old Oct 19, 2012 | 11:05 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Rubber Spring Isolators: Top, Bottom Or Both?
They go on top of the spring. Make sure you index them properly too. You'll see the pocket (indention) where the ends of the springs stopped in the original rubber isolators. The bottom end of the front springs should end up between the two "drain holes" in the lower control arm....it's in the Hayne's manual....
Old Oct 19, 2012 | 11:07 AM
toomany's Avatar
The rubber isolators go on top the springs. I usually use a few pieces of tape to keep them in place so they don't fall out of place.
Old Oct 19, 2012 | 11:50 AM
Confuzed1's Avatar
Car: 83Z28 HO
Good tip! I used small zip ties...
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
