weird front end issues. pleas help!!!
Old Oct 24, 2012 | 03:39 PM
jb1289610's Avatar
alright guys. i've been having an ongoing issue with my 84 camaro for a while and i want it solved. I switched a pair of ugly craiger ss wheels that were on my car for a good looking pair of alluminum slots. ever since i did the swap the front tires of my car, might just be the front driver one, always screeches when i make a left turn. almost like it isnt getting traction or something.
another problem i'm having is that at low speeds. 5mph-20mph. the car kind of hobbles along. like it has a limp. lol. anyway. these issues annoy me to no extent and i'd like some help in solving them. do the wheels need balanced? do i need different tires. whats up?
Old Oct 24, 2012 | 04:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: weird front end issues. pleas help!!!
What's the condition of the tires? How about the alignment? what size tires
Old Oct 24, 2012 | 04:31 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
all this happened after you swapped tires & rims . shouldn't that narrow down the problem area ? you either have bad tires , bent rim or both . used tires are like used condoms , you have no idea of their previous life . first jack up drivers side & spin wheel . if it does not rotate straight & true , there is your problem . (ck. both the wheel & tire) repeat with other side of car . good balanced wheels & are a no brainer . good luck .
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
sreZ28
Aug 14, 2015 07:48 PM
