83 Firebird Powersteering pump or gearbox bad?
Old Nov 11, 2012 | 09:19 AM
Kenshinx's Avatar
I have a 83 firebird, when I try turning the steering wheel it acts as if there is no powersteering or it makes a grinding noise. Increasing the RPM seems to sometimes effect if its easy or hard to turn.
I figured it was the powersteering pump but my father a mechanic said it was a steering gear. No one seems to know what this means other then the Steering Gear box yet when you drive it it turns manually fine just harder.
Anyone have any trouble shooting help or just a straight up it should be the pump, it would be greaty appreciated.
Old Nov 11, 2012 | 09:39 AM
Re: 83 Firebird Powersteering pump or gearbox bad?
PS system full of fluid? Any leaks?
Belts tight?
Old Nov 11, 2012 | 11:04 AM
Kenshinx's Avatar
Ps fluid full belts and pulley haven't checked. There is fluid on the fluid reservoir I'll clean it and see if leaks but fluid has stayed full I believe.
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
mustangman65_79
Apr 14, 2017 05:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
Newguy91rs
Aug 7, 2015 09:51 PM
