2001 Corvette in Junkyard
Old Nov 12, 2012 | 04:32 PM
91 outlaw's Avatar
Car: 1991 Camaro
Engine: 355 5.7L
Transmission: Turbo 350
Axle/Gears: 373
I just got a phone call about a 2001 corvette in a local junkyard. Alot of it has been stripped for instance motor interior trans axle. I am interested in the front end. Calipers control arms spindles and so on are all there possibly sway bar. Do you guys know of any parts that would bolt up to my 91 camaro?
Old Nov 12, 2012 | 05:05 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 2001 Corvette in Junkyard
Not a lot is going to swap directly. You're talking about putting parts designed for a Y Body on a F Body. Totally different frames.
You're best bets would be Rims to use or resell and Calipers if you plan on doing a brake upgrade. The calipers are still going to take more parts to make them work.
Something like this:
http://flynbye.com/catalog/i79.html
Old Nov 12, 2012 | 06:21 PM
Twin_Turbo's Avatar
a modified spindle and a bracket is all it takes to bolt on the complete brake system.
The brackets are easily fabbed but can be bought, you can buy a hub or turn down your existing rotor cutting and drilling/tapping the spindle is easy enough also.
Old Nov 12, 2012 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
only parts you could use, and none will just bolt on, would be int eh brake rotors and calipers. thats it.
armybyrd
Sep 28, 2023 12:16 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
