REAR COIL OVERS
Car: 86 camaro
Engine: big block
Transmission: glide
REAR COIL OVERS
Has anyone installed a rear coil over kit with the stock sumped gas tank? If so do you have any pics? I have a 9" under my car and want to put coilovers on it but thinking I may have to get rid of the tank but dont want to.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: REAR COIL OVERS
why would the sump be in the way? coilovers are no where near the sump. I run the wolfe racecraft rear springs and they use the 2.5" diameter springs with new spring pockets up top.
Car: 86 camaro
Engine: big block
Transmission: glide
Re: REAR COIL OVERS
So you run coilovers in the stock location? I was talking about the kits you can order that uss the qa1 shocks. It appears that I wont have any room with the tank in the way for the top mount bar that goes from frame to frame
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: REAR COIL OVERS
if you want coilovers, put them in the stock location.
Car: 86 camaro
Engine: big block
Transmission: glide
Re: REAR COIL OVERS
I went to wolfe racecraft site. may I ask what all did you use as far as shocks? And how did you mount your shocks in the spring perches? Just a little confused on how they bolt in. And thanks,was unaware of the availabilty to use coil overs in the stock perches. much appreciated
Terrell351
Jun 13, 2021 01:13 PM
