UMI New Product! 82-92 GM F-Body K-Member, Road Race
1982-1992 GM F-Body Tubular K-member, Factory Springs, Road Race
Applications:
Applications:
1982-1992 Chevrolet Camaro V8
1982-1992 Pontiac Firebird V8
Less weight plus high strength equals road race and auto-x success. UMI’s direct bolt-in replacement Road Race K-member instantly removes 20 lbs of front end weight from your ride and helps your existing horsepower work for you while providing a capable, high strength foundation. UMI’s RR k-member features strong dual tube construction as well as extra tubing and gusseting in critical areas. The K-member is fabricated from CNC machined 3/16” thick mild steel held together by a strong dual tube lower section. Factory clamshell and engine mounts bolt to the precision machined mounting pads while both factory and aftermarket suspension is located by strong boxed mounting points. Lightening holes are CNC machined into the mounting plates and the tubular construction provides added clearance for aftermarket exhaust. The modular design permits stock spring and strut use or simply remove the spring pockets and convert to coil-overs. Street and track testing on our test car has shown this K-member to be strong, reliable and a great upgrade for your high performance ride. Available in tough powder coated red or black finish. Manufactured with pride in Philipsburg, PA - USA
Features and benefits:
20 lbs lighter than stock k-member
Dual tube construction for superior strength (Industry leading!)
Four additional tubes plus two gussets in critical areas
Strong 3/16” thick mild steel engine & suspension mounts held together with 1-1/2” dia DOM tubing
CNC machined & jig-built for no hassle installation
MIG and TIG welded for clean looks & superior strength
Direct bolt-in design can be used with factory, UMI or other aftermarket a-arms as well as factory or aftermarket springs
Includes six new Grade 10.9 flanged mounting bolts
Durable red or black powdercoat
Modular design allows use of coil-overs and/or LS mounts for minimal cost
Note: This k-member will accept an LSX engine by purchasing motor mount adapters part # 2406. When using an LSX engine factory LS A/C needs relocated when running a UMI tubular k-member. We recommend an A/C relocation kit from www.kwikperf.com.
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Re: UMI New Product! 82-92 GM F-Body K-Member, Road Race
Very nice!!!
I already have full rear UMI Performance parts. Concidering this K member seriously with A arms....
Car: 1989 Trans Am GTA
Transmission: M28 T56
Caught this during your thanksgiving sale stuff. If I wasn't building a motor I'd have done a buy it now.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Please make it compatible with the factory LSx AC compressor.
Just a slight tweak & you are there.
More people could afford the k-member if they did not have to buy a new AC setup.
Thanks for the recommendation
Ryan
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
You had me until the A/C compressor part...bummer.
Car: 87' IROC
Does it allow the use of the factory front triangle braces?
How low is the main bar in relation to a factory oil pan?
Thanks,
John
Thanks,
John
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You only mention V8s. V6 guys want to lose even more weight too. Any fitment issues?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
It does use the triangular braces, since its a 'road race autox' piece, its nice to keep all the bracing, even if it costs you ac fitment for the lsx guys.
The lower crossbars are about as low as the stock k-member, which is nice, no loss in ground clearance. The bar is dead nuts even with the bottom of my v6 pan, whic should be about the same as the standard v8 pan.
I installed one of these in my 92 v6 car earlier this year, I'm working on the write up, but life has been busy and work is killing me, so finding time to finish it is hard. Hopefully soon.
Car: 87' IROC
Fits a v6 just fine, but you have to make adapters for the motor mounts since the kmember does not have the v6 motor mount provisions. I made a set, and have pics. Pretty simple, but takes some work. The removable spring perches are nice, I made my own to work with my weight jack setup, keeping the bolts up and through the frame.
Car: 1989 iroc convertible
Engine: 305 tpi
Transmission: 700 r4
Just wanted to say thanks got my package today strut tower brace, subframe connectors , and steering brace look great nice job guys cant wait to getem on Re: UMI New Product! 82-92 GM F-Body K-Member, Road Race
Yes sir, they do. We make them for the 5.0L engine, it would be a direct bolt in with no modifications. They work with factory a-arms as well. Below is non-road race version for your vehicle if you would like to look:
Part #2401- http://www.umiperformance.com/catalo...roducts_id=623
If you have any questions please ask. Thanks!
Ryan
Ryan
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Group purchase maybe? Real beefy looking piece.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Hmm my motor is out again and i have been considering kmember for more room. Any pics of this along side a stock kmember and a arm setup to show differences?
My turbo setup clears stock kmember so i should have no problem with tubular.
Think it will hold solid motor mounts and 1000-1100 hp?
Car: 1989 IrocZ
Ramey emailed me if I could get at least ten orders they may be able to do something. Orr, will you be going with the RR unit? By the looks of the construction, Im sure the 1000 is doable. Really good construction by far of any k member ive seen for our years. Im basically looking for clearance , but theweoght savings is a plus. Suscrib so we can keep on top of this.
Mods... Let us know if it is ok to garner intrest here the if need be move this over to the gp forum. Thank you
Car: 88 sport coupe
Engine: 2.8
Transmission: auto
I'm liking the looks of this unit. I will just have to make some adapters for the big block Buick I plan on using.
Car: 92 Z28
Engine: Boosted LSX
I might be in. I need to know if the main under oil pan hoop is in the same location as the spohn kmember.
My turbo setup clears a spohn setup. Hate to buy this road race one and have issues.
Car: 1989 IrocZ
From my perspective looking at both manufactures pics it seem the umi's has more of a loop, u shape, than the spohns unit, which looks like a straight shot cross bar welded in at a little bit lower point than umi's. Thats what i see from the pics, but im sure umi can chime in here as im sure they reserched all competitors units before designing there own. Give em a ring tm, its the last day. Hell of a deal on the rr unit after discount and the bargain shipping.
Off hand btw, what is making you consider the switch since you have one already? Heard of hit or miss problems with spohns k members in searched posts here, but seems not anything negative about Umis design, especially the rr unit which seems to be a heavy duty piece. Take care.
Car: '89 Firebird
Engine: 7.0L
That was a bonehead decision to make a tubular K-member for LSx swaps that can't be used with factory AC compressor brackets. Get it right. Understand the voice of customer.
Car: 87 Camaro
Engine: small block
Transmission: 5 speed
Axle/Gears: 10 bolt posi
My brother and I are building an 87 coupe for playing around on the auto cross...what products would you recommend from your company. We are just starting the tear down process this winter. Just curious as I keep getting conflicting info from various people. any help would be greatly appreciated.
I suggest reading the magazine articles hosted on TGO, as well as the Sticky's in this chassis/suspension forum.
You can order that package via phone already. You'd just specify you wanted the RR instead of the standard k. It would be P/N 240731.
thanks
ramey
Thanks for the orders everyone!
We are building these as quick as possible, we are out a week on some of these items from our sale so please bare with us. We appreciate it.
I attached a few pictures I snapped last night before I went home.
Car: 89 Iroc-z
Transmission: TH400
I got 3 months before i really need it lol. Got plenty to work on before i get to that install. Looking forward to it.
Car: 1989 IrocZ
No rush for me. Im still waiting for my plowed piles to thaw for the ups guy to deliver to my back door. Will you be sending out emails when my order is reqdy to ship? Thank you
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Car: 1989 IrocZ
The ones umi sells are they stock triangular pieces or reproductions?
Car: 1989 IrocZ
Great mine are already powdercoated black to match the rr k.
Car: 89 Iroc-z
Transmission: TH400
I am going to try to twist this k member in half with my motor
block will split or kmember will let go when i am done
Engine: 4++,350 & 305 CIs
cant wait to rid my car of this nasty POS K thats in it now..
Car: 89 Iroc-z
Transmission: TH400
Received my k-member today. Looks good. Construction looks good, cant wait to install it.
Car: 1989 IrocZ
Lol, couldnt believe the size difference when you actually get them side by side. Def alot of excess metal on the stocker. Umis piece is a gem. Im just prepping my mout areas and retouching the paint there. Btw TTOP350 didnt you tell me in the motor mount thread your car came with two drivers side clamshells factory? Im thinking of throwing the es mounts back in and its a breeze to swap things out with the umi setup compared to the factory nightmare.
Im in the market for a kmember i already ordered amd installed your trans crossmember and torque arm package, but i would like the kmember with provisions to mount the pinto rack and pinion
Thanks for the interest.
ramey
Thanks ramey for the quick reply. Do you know if in the near future you guys will be workingon that? I really dont want to mix and match my suspension components.
That rack mount isn't on an official list yet but it may be someday. If the requests pile up, we move projects up to the front...
Car: 1989 IrocZ
Ramey ,
Any chance UMI will be offering the triangle pieces that brace subframe and k member? I know some cars didnt come factory with them and in the bone yards, at least around here they are usually bent ot dmaged beyond use. Thank you
