Air Shock problem solved
Old Dec 7, 2012 | 02:45 PM
305TBI's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Axle/Gears: 4.10
I installed P275/60R15, 107S B. F. Goodrich tires on the rear of my 91 firebird formula. The tires are bigger than stock and sometimes make contact with the fenders when I go over a bump, so I installed Monroe Air Shocks to correct the contact problem. That worked great for a long time, but the air shocks or the tubing that connects to the shocks began to leak air. I replaced the tubing with a new kit, but that did not solve the problem. Now I had to decide if I should replace the air shocks or install different springs. I had a pressurized can of "fix a flat", so with nothing to lose, I filled the air tube connected to the air shocks with the contents of the "fix a flat" and then injected 65psi of air. Three months later and no loss of air. Wherever the leak was it is sealed now. Air shocks are going to leak sooner or later, so "fix a flat" may be a solution.
Old Dec 7, 2012 | 04:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Air Shock problem solved
So much fail...
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
