Strut Tower Braces that bolt to Struts
Old Nov 14, 2012 | 08:05 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Ive been searching and can't find much. I believe that the UMI STB bolts to the strut mount and doesn't require any drilling. What are other strut braces that mount without any drilling?
Old Nov 14, 2012 | 08:31 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Strut Tower Braces that bolt to Struts
UMI makes theirs that uses 2 of the strut tower bolts & has a 3rd hole that is entirely optional for you to drill to mount it to the strut tower. Mine has been on for several years & I have never drilled the hole for the 3rd mounting bolt to be put in.
http://www.umiperformance.com/catalo...roducts_id=126
Old Nov 15, 2012 | 05:12 AM
tagolf2000's Avatar
Car: 1987 IROC
Axle/Gears: 2.73 Now 3.42
I recently purchased and installed the strut tower brace from Mac. It is pretty good quality, could notice a difference and it looks pretty good. Mine is tpi with driverside A/c and it fits real well. It does fit fairly close to the upper intake. Make sure you have some good engine mounts if you go with the MAC STB.
Old Nov 15, 2012 | 08:22 PM
Axle/Gears: 4.10
Cool thanks for the info. Are there any bolt on struts that have the style of the hotchkis strut tower brace?
Old Nov 15, 2012 | 08:29 PM
Car: GTA
If you mean a 3-pt, ALL 3-pts will have to have holes drilled for the firewall mounting point since there are no holes anywhere along there to use as mounting points.
Old Nov 15, 2012 | 08:40 PM
Axle/Gears: 4.10
I meant a STB similiar to BadnBlk's. I like this style below better than the single bar such as the UMI stb.
Old Nov 29, 2012 | 10:04 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
No, they will require that you drill. What is your hesitation with drilling holes?
Old Dec 4, 2012 | 08:57 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
what stb is that
Old Dec 4, 2012 | 09:11 PM
Car: GTA
That wouldn't fit under a Firebirds hood, due to the lower hood line. Even the UMI one BARELY fits & it has the bottom of the cross bar notched out for the intake plenum.
Old Dec 7, 2012 | 06:46 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hotchkiss STB
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
