Clunk in front end
Old Dec 9, 2012 | 05:29 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Clunk in front end
I just recently finished my complete over haul on my suspention. Parts included:
UMI K-member
UMI LCAs
34MM sway bar, Moog bushings and endlinks
KYB AGX shocks with KYB shock bumpstops and dust boots
Founders Performance Upper strut mounts
Wonderbar
Quick ratio steering box
Moog inner and outer tierods
UMI tierod adjuster sleeves
Eibach Pro-kit springs - WITHOUT rubber isolators on the top of the springs.
I've only put 1 mile on it for a shake down (Rebuild the drivetrain too) I've found on hitting bumps, like smaller pot holes I have a noticable "Clunk" or "Thud" noise in the front end. I haven't had a chance to get it on jackstands yet. Anyone have ideas on what to check first? As far as I know, Everything is tight.
Old Dec 10, 2012 | 07:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Clunk in front end
are the shocks fully seated in the strut mounts? you cant always use the factory dust boot if thats what you are using. check that first.
Old Dec 10, 2012 | 07:57 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Yep, Shocks are seated. I'm using the KYB dust boots that KYB recommends
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
shocks and calipers... dont ask how I know about the second one....
Old Dec 10, 2012 | 08:18 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Calipers are tight. Double checked that today. Shocks are seated and tight in the upper mount and the mounts and the spindle.
I think its the spring shifting in the perch. While jacking the front end I had clunks and creeks from the springs shifting. If thats all it it, I can probably ignore it.
Old Dec 20, 2012 | 04:53 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
upper strut mounts?
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
