Greaseable versus non-greaseable
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Looking to replace the rear sway/front sway bushings and end links. Also will replace bushings in the a arm and other locations as much as necessary.
That said....
I see there are greaseable options and non greaseable options...
What are the differences and what is recommended?
Don't plan on racing.. Just take out some aggression on the street
That said....
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: Greaseable versus non-greaseable
I think it's a no brainer to go with the greasable bushings. This way if the poly starts to make noise it will just take a few seconds to re grease with a grease gun on the zerk fittings. If you don't go with the greasable you will have to remove the bushings every time you re grease.
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
If you are going through effort of replacing a-arm control bushings, you may want to grab some del-a-lum bushings from global west. They are aluminum sleeves with plastic inserts and grease fitting. Supposed to give you best control arm response by having no bind. http://www.summitracing.com/parts/gl...model/firebird
Engine: 4++,350 & 305 CIs
I use anti-seize on the poly when I put em together. It works waay better and lasts longer.
The grease they use will squeak when its cold out.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I think the sway bar bushings kit that TDS sells would be the best setup. Good for ease of greasing as well as corrosion protection.
http://www.top-downsolutions.com/cha...amaro-or-fireb
http://www.top-downsolutions.com/cha...aro-or-firebir
I seem to recall Lon saying that the TDS kit is the only one with a true fitting 36 mm sway bar setup for the front end. That the other kits out there aren't really 36 mm. I'm not sure what size sway bar you have up front. But his kits have multiple sizing options anyways.
Car: 89 Formula 350
I have the TDS sway bar bushings and I'm very happy with them.
Just ordered TDS for the rear....looking forward to it.
99Hawk120
Nov 10, 2011 08:07 PM
JamesC
Aftermarket Product Review
Sep 14, 2002 09:35 AM
