What size is the bolt that hold the steeing col to the lower shaft
Old Jan 7, 2013 | 05:39 PM
blakecharles's Avatar
What size is the bolt that hold the steering col to the lower shaft?
What size is the bolt that connects the rag joint to the steering box?
Can I just use grade 8 bolts that fit? or do they need to be properly threaded?
Old Jan 7, 2013 | 06:04 PM
Re: What size is the bolt that hold the steeing col to the lower shaft
steeling some pix...
the bolt that go's in the end of this
I need the bolts that go on both ends of this
Old Jan 7, 2013 | 07:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They're both special bolts.
Old Jan 7, 2013 | 07:38 PM
Dang!!!! so I gotta go to the junk yard???
Old Jan 8, 2013 | 01:52 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
yeah, but they aren't super duper rare or anything- pick an 80's GM product with the engine out for easy access and take the bolts you need... cars, trucks- whatever.. should all be the same.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
MENINBLK
Aug 5, 2015 11:58 PM
