Springs and spring isolators
Old Jan 24, 2013 | 09:30 AM
dynodave's Avatar
Car: 1991 Z28
Engine: L98 350 TPI
I'm installing Tokico lowering springs and I'm wondering what to do about isolators. Should I go rubber, urethane or no isolators at all. Springs should lower car about 1 1/2". My concern is noise without isolators. Any advice would be appreciated..
Old Jan 24, 2013 | 12:08 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: Springs and spring isolators
I used heater hose on mine and it worked well with no noise.
Old Jan 24, 2013 | 10:19 PM
dynodave's Avatar
Car: 1991 Z28
Engine: L98 350 TPI
Do they have top and bottom isolators like my Mustang did?
Old Jan 25, 2013 | 05:39 AM
jbenge's Avatar
The fronts have a piece of rubber on the top of the spring and nothing on the bottom. I wrapped some electrical tape around the top coil of the spring and the rubber isolater to keep it from falling off during installation.
The rear springs have an isolator on the top, nothing on the bottom. I removed the isolator and pushed a heater hose onto the first coil to keep it from making noise on the rear.
Old Jan 25, 2013 | 04:03 PM
BMR Tech's Avatar
Former Sponsor
The heater hose if a very popular mod. Before you install them, take your springs to a parts store and find a small diameter heater hose you can cut down and slide over the spring. Should work just fine and keep things quiet!
- Kevin
Old Mar 30, 2013 | 11:26 AM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
Are the rear isolators the same as the front? I only find the front application everywhere I've looked.
Old Mar 30, 2013 | 12:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Really, skip the isolators and use heater hose. It seems to work just as well, I can atest.
Old Mar 30, 2013 | 01:13 PM
Engine: 305 (LO3)
I might use heater hose. But are the isolators the same?
Old Mar 30, 2013 | 01:32 PM
Tibo's Avatar
Car: 1991 Z28 Vert
From my car, the rear isolators were thicker than the fronts. The rears were about an inch and the fronts were 1/4 inch or so.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
