Good rear coil springs
Old Feb 3, 2013 | 11:16 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Im looking to replace the rear coil springs since my rear end is getting rebuilt looks the springs i have in now have been in since 1988 i was wonderig what are the best stock ride height springs. An also do i have to use the rubber spring pad or can i just put the new springs in with out it
Old Feb 3, 2013 | 11:23 AM
Re: Good rear coil springs
Moog CC635
Leave the rubber pad in
Old Feb 3, 2013 | 11:38 AM
Engine: LR4 4.8
Can i just wrap heater hose through the coil spring an give it rubber support it will also lower the car a little bit
Old Feb 3, 2013 | 04:15 PM
I wouldn't wrap it "through" it; it works to wrap it around the end coils though.
Old Feb 3, 2013 | 06:48 PM
Engine: LR4 4.8
Yea thats what meant just wrap it through the bottom coils where it meets the top of the frame rail, an the rear end mounts
Old Feb 3, 2013 | 09:37 PM
No, don't wrap it "through" anything. Wrap it around the wire the coil is made of.
Imagine it as being a coating. Slit it down one side or slide it over the end. (depending on what size of hose you use)
Old Feb 4, 2013 | 07:08 PM
Engine: LR4 4.8
Ahhh alright i know what u mean now slit the hose then slide it over the bottom of the coils so its not metal on metal when installed in the car
Old Feb 4, 2013 | 07:23 PM
Yup, that's prety much it
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
AkDrifted
Aug 17, 2015 07:45 PM
TA8487
Aug 11, 2015 09:02 PM
