Tokico VS Prokit
Old Feb 19, 2013 | 10:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Tokico VS Prokit
I went to install drop springs on my ride only to find out that I already had Eibach Prokit on my car. I wasn't happy with the ride height at all, and the prokit had to have been installed before I bought the car 12 years ago. I would have to say the should have been plenty settled.
If possible, I would like to cut the Prokit to drop it another half an inch or so. I don't know how much to cut off...
So I would like to just keep the Prokit since the Tokico springs only say they drop the car 1.25/1.5". I could sell the new Tokico springs.
Should I just install the Tokico springs or cut the Prokit? I need an answer by tomorrow. What would you do?
Old Feb 20, 2013 | 05:15 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Tokico VS Prokit
Id avoid cutting springs if i were you. I dont have spring rates and such in front of me for the tokicos so i cant compare that but i know the prokit only drops the car 1 inch which is not enough for some. I have the prokit in mine and like the stance and ride quality it gives. If you want to go lower will .25/.50 more be enough for you is the big question. If yes then throw the Tokico springs in there.
Old Feb 22, 2013 | 07:30 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I ended up going with the Tokico springs. It dropped the rear another 1" or so, and the fronts stayed the same. I am sure they will drop a bit more once they settle.
The old front struts were blown, so the ride is AWESOME now! I am running the adjustable Tokico struts running them on 3 all around. If anyone wants my fender height I can go measure.
Old Feb 22, 2013 | 09:19 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Sure. From the ground, through the center of the wheel to the wheel well lip.
Old Feb 23, 2013 | 09:08 AM
subroc's Avatar
Engine: 355 TPI
Good deal! I have been running the prokit with tokico illumina struts/shocks for about a year now and like the ride as well. I have the front set to full stiff and the rear set to 4. I may or may not lower it down for a bit smoother ride but i like to feel whats going on with the road. Those two things plus the BF goodrich pro comp 2's were the best thing i did as far as handling for this car.
TKD89RS
Nov 16, 2001 09:23 AM
oldblueZ
Apr 16, 2001 04:04 AM
CleanRS
Aftermarket Product Review
Apr 1, 2001 08:07 AM
MelloYello
Jan 19, 2001 09:04 PM
86Trans Am
Jan 12, 2001 10:55 AM
