Problem fitting stock k-member
Old May 3, 2013 | 12:51 PM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
After removing the k-member and modifying it to clear a f-body LS1 oil pan I'm having some trouble. I got the front holes to match up with little issue but the back two (ones that use the small bolts) are out about 1/2" on each side.
The car has sat pretty much stripped on jack stands for two months, subframe connectors were installed prior starting the swap.
Is there a chance the chassis has separated? Maybe the k-member warped a bit when it was welded? Am I okay to just open the holes up a bit on the k-member so I'm able to get the bolts in, or what is the best alternative.
Thanks for the help.
Old May 7, 2013 | 08:28 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Problem fitting stock k-member
K-member bolt holes are just tapped floating plates sitting inside the front framerails
If you can get 4/6 in, then the last two are just out of alignment some. Leave all the bolts loose and use a screwdriver to slide the rear plates into alignment before threading the bolt in
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Grant2k
Jul 10, 2018 04:01 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
NBrehm
Aug 5, 2015 07:57 PM
