Racecraft RR drop spindles what now?
Old May 13, 2013 | 12:37 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Now that Racecraft won't do the RR version of the drop spindles any more and no-else makes one what can be done? What is required to "home" modify the spindles to handle track use? What material, where and what sort of welding? Anyone with pictures or drawings of what would be needed? Any other practical way to achieve the same result? Modified A arm? Extended ball joints? Both?
Old May 13, 2013 | 02:18 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Racecraft RR drop spindles what now?
I run extended ball joints and it lowered the car enough for me, although not as much as dropped spindles. I am at about 26.5" on front passenger side and 27" front driver side center of fender to ground heights. Extended ball joints raise the roll center and make turning better by decreasing front roll as well as lowering overall center of gravity. The only gripe is that they induce bump steer, which needs to be corrected with a bump steer kit.
Old May 13, 2013 | 03:18 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I use the car for some running around but I keep it really for auto-x and track days when I can afford them. So I'm reading everything I can and I'm trying to do stuff the 'right' way. The drop spindles are a long term goal but I have a lot of other stuff to do before I really need and can afford them. Just keeping tabs on what's available.
Old May 13, 2013 | 11:38 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
You could always buy their "Drag Race" spindles and modify them, that is all they did. The basic design is the same
Old May 14, 2013 | 03:27 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Belltech used to make spindles. You might keep an eye out for some, if there are still any left in the wild. Alternatively, just run extended ball joints. They've been discussed on here and on FRRAX, and they do affect bump steer, but only at extremes of suspension travel and IIRC it wasn't very much.
A lot of drift guys run modified steering knuckles to change ackermann as well as get more steering angle at full lock, and many just modify the stock spindles. I have no idea how beefy they are and if they'd be safe enough to run on the street (as opposed to in an arena, where the worst thing that will happen is spinning out if something goes wrong). If you can find someone that knows what they're doing you could see if they could modify a set of spindles from the junkyard.
It'd be nice if thirdgens got a bigger following in drifting, I know a lot of members hate it but think about it... the Nissan S-chassis and Toyota AE86 both use McPherson struts and have an insane aftermarket dedicated to playing with suspension geometry, and are very well respected, while the aftermarket for the thirdgen is smaller and they aren't as well regarded despite being pretty similar...
Old May 14, 2013 | 07:02 PM
87350IROC's Avatar
Car: 87' IROC
There is no good way to modify them. The basic design is flawed relying on the spindle pin being held to the spindle with a weld in bending. They should be pressed in like stock. The design cannot be saved IMO.
Old May 15, 2013 | 09:32 AM
Time for another company to pick up where Racecraft left off and make some 2" and 1.5" drop spindles.. Heck.. Even 1" dropped spindles would sell I think.. Pair the 1" spindles with 0.75" extended ball joints and you have lower CG and you can still run wide wheels probably still fit the outer tie rod inside the wheel with 17" wheels (don't quote me on that one.. But, I would assume so?)
Old May 15, 2013 | 03:59 PM
fenton06's Avatar
They are pressed in before welding, as stated in the other thread.
Old May 15, 2013 | 04:11 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
How is that pressed in, it's completely open on one side
Old May 15, 2013 | 04:56 PM
87350IROC's Avatar
Car: 87' IROC
I can't be. If it was pressed in like stock, there would be no need for a weld. And even if you welded it, it wouldn't break.
Old May 15, 2013 | 04:57 PM
87350IROC's Avatar
Car: 87' IROC
Exactly. I can't believe the Racecraft guy in the other thread even claimed it to be pressed in. How dumb do they think we are.
Old May 15, 2013 | 05:26 PM
fenton06's Avatar
I've seen them... The Mustang ones are pressed in and then welded as well. If you take the third gen spindle and try to put it into the main plate that comprises most of the spindle it won't slip in to be welded.
The people in this forum have made up their mind that these spindles are junk, but there is a reason other companies aren't making them and that's because it's a tough design.
If it's so simple then design and sell some if you think the market is worth the investment.
Old May 15, 2013 | 06:24 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
My idea,
Use something like this:
http://www.colemanracing.com/Spindle...-5--P4710.aspx
Machine up a new strut mount, maybe tie it into the lower LBJ/Tie rod mount somehow. Spend hours laying out a workable layout in CAD modeling all sorts of existing parts to make sure it'll all fit. Then run hours of kinematic analysis to make sure it'll be an improvement over stock. Finally brew up some drawings and pay coleman a small fortune to machine the new parts.
In one fell swoop you can get rid of the anti-ackerman steering, give people an option to run a wide variety of hubs like wide 5 or 5x5, and still lower the car with superior geometry.
Old May 15, 2013 | 07:35 PM
fenton06's Avatar
Originally Posted by Roostmeyer
My idea,
I dig it, I actually have been kicking around doing something like that in the back of my head. I'd like to use
http://www.kartek.com/Product/302/2-...le-Snouts.aspx
and have a completely bolt together piece! I will have to do some digging, the only problem would be trying to keep their wheel in the stock location with the hub and figure out what to do with the strut mount. I wish I had a CMM at my disposal, I am pretty **** about thing being right, and having an accurate starting place is paramount. Really just need lower balljoint placement, spindle centerline and strut mount. Everything else can be tweaked as needed.
Old May 15, 2013 | 10:17 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
What's the answer? Pressed in and welded or not pressed in and only welded?
Old May 15, 2013 | 10:23 PM
I like where this is going.. lol
Old May 15, 2013 | 10:34 PM
fenton06's Avatar
Pressed in and welded. Part of it is open yes but it is still an interference fit. It's only like this because moving the spindle up 2" gets it very close to the strut mount, hence why it is not a 360* weld like their mustang spindles.
Old May 16, 2013 | 01:24 AM
87350IROC's Avatar
Car: 87' IROC
It is better to recognize something isn't going to work and not do it than to do it, put peoples lives at risk and then say, hey its hard, at least they tried.
Engineers make these decisions every day.
The interference between the spindle pin and the strut mount indeed makes the design a challenge.
If the spindle pin is pressed in, why do they bother to weld it? And why did the press fit fail?
Old May 16, 2013 | 01:26 AM
87350IROC's Avatar
Car: 87' IROC
My idea,
All that for what, 5-6 sales a year?
I think its a great idea for personal use, just not a marketable one. I think that was your point though.
Old May 16, 2013 | 09:29 AM
Then why don't you guys do a 1.5" dropped spindle instead? 2" is too much for most people on the street anyway.. 1.5" seems right and if it could be strong enough for street, it would be a seller.
Old May 16, 2013 | 10:06 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Sounds reasonable. Spring change or 1 inch smaller diameter tire would give the other 1/2 inch if really needed.
Old May 16, 2013 | 11:47 AM
SlickTrackGod's Avatar
On Probation
You guys are seriously chatting with this brain surgeon? he's proved his ignorance on the other thread.
The only idea of his I would invest in is his ability to take a ****
Old May 16, 2013 | 12:41 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Not really chatting. I was looking for ideas or advice on how to get a safe drop without messing up the front geometry. I don't have the depth of knowledge or experience to be sure of what is possible or practical. Can the current spindle be modified 'at home' to handle auto-x or road racing? If not then what? Custom (expensive) set ups? Ball joint, A arm or spring mods? A combination? I for one am trying to read everything some of you guys write about this stuff but there's a lot to assimilate and no 100% agreement on some of it.
Old May 17, 2013 | 03:05 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
The fools in this forum have made up their mind that these spindles are junk, but there is a reason other companies aren't making them and that's because it's a tough design.
fixed for you,
Old May 17, 2013 | 04:13 PM
err.. fools? They broke at the weld which could have meant death for the driver and/or people around him racing. Who is the fool? They look good and give a 2" drop which is amazing.. But there is a design flaw that needs to be addressed so that it won't break and kill someone. We are not fools, we are being cautious with the parts that are available for our cars.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
