UMI k-member and ground control weight jacks?
Old May 17, 2013 | 01:50 PM
Blowtorch79's Avatar
Car: 1989 Formula 350
Engine: 383ci, +150hp N20
Transmission: Built 700R4
Axle/Gears: Moser 9", 3.73 Detroit locker
Any issues with this combo? Anyone have some pictures? K-member is already installed. Getting ready to add some Founders caster/camber plates. Thought it might be a good idea to toss the sportlines....
Thanks,
Old May 17, 2013 | 04:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: UMI k-member and ground control weight jacks?
Might have to make something to take up any difference in diameter of of the spring perch ring vs the jack, somebody did it with a bmr piece iirc and just used some heavy wall rubber tubing.
Fwiw, you would just buy a weight jack nut plate and weld it to the perch of the kemember and run the jack bolts up through the frame rail into the engine bay, not that hard to do and a lot cheaper than the GC setup.
Old May 17, 2013 | 06:47 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
If its set up for stock springs there will be no problem at all. I have weight jacks and they fit right in the stock pocket.
You can also do as 86TA said but there is nothing for the rear springs except ground control or fabbing something up.
When I looked at fabbing up a system with parts the savings did not make up for all the extra work and if you have your fabbed stuff powder coated there is no real savings.
Really price the parts and springs before you fab stuff together. Ground controls system is proven and comes with a lifetime guarantee.
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
