Founders rear kit
Old Jun 2, 2013 | 01:20 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Founders rear kit
Just ordered the Founders Performance non adjustable rear end kit. I am hoping it is as good as people say it is. Are there any tricks/concerns/prep work that need to be addressed for a good install? Or is it just a "out with the old, in with the new" kind of thing? I am buying new bolts for the LCAs and Panhard Bar, and gonna get the Spohn Super Lube grease.
Old Jun 3, 2013 | 09:08 AM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Re: Founders rear kit
curious as well, thinking about ordering one too. Bent mine yesterday trying to get it out so I could replace coil springs. Oh well, time to upgrade I suppose. The stock one is a piece of junk after 30 years.
Old Jun 3, 2013 | 09:36 AM
Veaceonee's Avatar
I am going to hold off on installation until I can get springs and shocks. Got it tore apart anyways, might as well.
Old Jun 3, 2013 | 09:41 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Check these out...
http://steinjager.com/shop/index.php...ol+Arms&page=3
Old Jun 3, 2013 | 03:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Check your local Ace Hardware for the SuperLube grease. I found it there far cheaper than Spohn and I didn't have to have it shipped either.
I've removed an installed my factory PHB a few times now. Yeah it's the last suspension piece I need to be total aftermarket (minus the sway bars I already have WS6). You should keep track of which side the bolts came out of. They are different sizes. I reinstalled them wrong the first time and guess what after I had one side totally tightened down I couldn't get the other side to fit. I put the smaller bolt in the larger hole.
LCAs there isn't much too them. I would recommend only doing them one at a time. Trying to put both on at once (did during a 10 bolt swap) was not fun.
Old Jun 3, 2013 | 06:26 PM
Pocket's Avatar
Car: 91 Trans Am
I have the adj rear kit from founders and it really is a simple R&R
Bolts should come with the kit. If they dont, you want grade 10.9's for metrics. Hardware store 8.8's are approx a grade 5 in SAE. You'll probably have to hit up fastenal or McMaster for those
Old Jun 3, 2013 | 08:04 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
I just installed Founders rear control arms and Panhard bar on my 1988 Formula 350. A good product at a reasonable price. Very pleased with them so far, tightened up rear suspension a good bit, no more rear axle steer or hopping under hard acceleration.
Old Jun 3, 2013 | 08:33 PM
nhgator's Avatar
Car: 1985 T/A
I put a Founders set on my T/A,was fairly easy,did not come with bolts but my local gm dealer had them in stock.
I also did sway bar end links and bushings and installed a wonder bar up front,car feels much crisper now in corners now,no more swayback maru lazy corner feel.
Old Jun 4, 2013 | 07:34 AM
Veaceonee's Avatar
I am changing out the bolts on both the LCAs and the PHB. Got the LCA bolts with the parts and getting the PHB bolts from Hawks. Im glad to see a lot of positive news on this kit.
Old Jan 17, 2014 | 08:10 PM
FoxBodyeaterZ28's Avatar
Car: 1983 camaro Z28
Engine: SBC 383 stroker
Transmission: TH350 2800 stall manual valve body
Axle/Gears: 7.5 10 bolt 3.73 Posi
Hey I just ordered my founders performance PHB and LCA's can't wait to install em on my 1983 Z28, Happy to read so many Good reviews. Plus u can't beat that price wit a baseball bat.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
