Wonderbar/Steering Brace
Car: 91 Z28 Coupe
I was looking to install a Wonderbar on my 91Z (since GM decided not to put one on). I was wondering what brand should i go with? I could go used OEM off ebay for around $20. Or I could go with Spohn, UMI, or other aftermarket brand, for between $55 and $90. Looking for some input as what would be the best option with direct bolt-on. Also Spohn has an adjustable wonderbar for $100. Why would I need an adjustable one? Is it worth it?
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: Wonderbar/Steering Brace
To be honest, I am not sure how much they actually help. People swear by them. My brother has the factory one and I picked up a used UMI. The UMI is much bigger than the factory one....Almost double the size.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The factory one is perfectly adequate and much lighter than the aftermarket ones.
Car: 91 Z28 Coupe
Posted from Thirdgen.org App for Android
Car: 86 IROC
Axle/Gears: BW 3.27
I am not looking for performance gains in handling, I am just looking to reinforce the front the way it should have been.
Car: 86 Formula 350
Axle/Gears: 331
wonder bar and strut tower brace well worth the money to stiffin up the the car sub frame connector too and you can feel it some say you can't but i did..!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Some non factory ones dont work with dual fans, keep th at in mind too
I don't even know if GW still makes one but THAT one is certainly stouter and heavier than the stock one.
You shouldn't notice any difference in handling from adding one unless it's already too late. It's more a preventative measure to box the front frame rails and keep rail that the steering box mounts to from flexing or cracking.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Probably your best bet direct bolt-in would be a stock one. Have one on my '88 Firebird. Firmed up the steering and stability in the front. It probably was already too late, but I did notice a difference. Have a Spohn adjustable on my '91 Firebird. Picked it up from a TGO member because it was a good deal. Supposedly if your raising or lowering your vehicle you will usually go with an adjustable. '91 drives better too. This is addition to the 36mm/24mm swaybars on the '91 and 34mm/23mm on the '88 and Founders panhard bars, as well as LS1 aluminum driveshafts, on both. What I've added so far has been well worth my money. Good luck with your additions.
Car: 1987 Camaro SC
Engine: 2.8L V6
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The "steering brace" strengthens the chassis, taking stress from the steering box area which is well known as a weak area on any third generation F-Body.
This is what I installed.
https://www.thirdgen.org/forums/afte...r-bar-1-a.html
Car: 91 Z28 Coupe
Originally Posted by 87 Camaro Dude
Quote:
Raising or lowering your car does not effect the steering brace.
Engine: TBI,5.0
This is what Sphon has to say about the adjustable bar = What the adjustment allows you to do is place pre-loaded tension on to the front sub frames. It makes for a very tight front end!=
http://www.spohn.net/shop/1982-1992-...djustable.html
Car: 1987 Camaro SC
Engine: 2.8L V6
I'm still not so sure that the normal steering brace really helps handling to a noticeable amount. I do think it's an important part that every third gen should have to prevent damage though. I've been autocrossing my Camaro for the past 5 months now without one, but I'll have a wonder bar on for the next event. I'm curious to see if I'll be able to tell a difference.
Engine: TBI,5.0
It seems to me that GM recognized a problem so they added a steering brace to fix it. Why they did not include it on all the cars is up for debate.
I've added a lot of things to my car that are not absolutely necessary. Cowl hood, wing, corvette servo, wider tires, etc. so why not install a brace that may help the car.
As 87 Camaro Dude mentioned
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I put a TDS wonderbar in my 92 RS. I chose the TDS bar because of the extra holes. Probably doesn't make a difference but it can't hurt. Probably doesn't matter what brand you go with but i wouldn't go without one. GM decided the IROC needed it, so i decided my RS needed it too.
Its a lot like subframe connectors, you don't have to have them but its better for the car if you do.
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
A steering brace (wonder bar) strengthens the chassis so the steering box does not tear itself from the chassis. The greatest stress is when you take slow steering lock turns such as in a parking lot. A wonder bar is cheap compared to repairing the chassis where the steering box tore itself off.
Because a wonder bar strengthens the chassis, it probably improves handling. But, as RonUSMC noted above, the main benefit is preventive.
I also agree with everyone else that the brand does not make much difference. However, I've seen some of the V8 owners complain about routing the radiator hose around the wonder bar. The 2 bolt hole one may give you an option to help with that problem.
I installed a sale priced UMI wonder bar at the same time I replaced my front sway bar with a 36 mm and the rear with a 23 mm. Serious improvement in handling and stability cranking through the corners. Wonder bar probably helped, but the bigger sway bars made the greatest difference.
Hope this helps.
Hope this helps.
Car: 91 Z28 Coupe
Well, like I said, the car is a 91 with 18k miles. I have another 3rd gen, and it has felt the tolls of time. I was looking to preserve the car I have now. I know the bar will not enhance the performance, but I am looking to save the car for the future. So, from what I can see, any brand Wonderbar will work thanks for the responses
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
I like the fit and finish of the Global West Wander Bar plus it's cheap.
http://www.summitracing.com/parts/gl...4/applications
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I heard the same think about them working wonders thus called "Wonder Bars". I bought one from Hawks off EBay. The price was rite and it is nice. I will let you know how it installs.
