wheel hop issues
Old Aug 23, 2013 | 11:40 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
wheel hop issues
ran the 86 iroc at the track tonight first pass no issues and the next 2 all had some sort of wheel hop and sounds almost like a clunk from the rear end area when on staging lanes , I broke the tranny mount and replaced it before I raced but it still hasn't felt the same scince I broke it, it is a 5 speed car and when it was broke the shifter lifted up when driving it still seems to lift alittle not sure if that's normal , is the mount somehow still causing this even tho its not broke now or what else could be?
Posted from Thirdgen.org App for Android
Old Aug 24, 2013 | 05:33 AM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: wheel hop issues
If your car is lowered at all you need Lower Control Arm Relocation Brackets. (LCARBS) The LCA needs to be at least parallel with the ground, if its on an upward incline from the chassis to the rear, it'll wheel hop just like you are experiencing.
If you're still at stock ride height, worn out old suspension parts might be the problem.
Old Aug 24, 2013 | 08:22 AM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
its all stock on the street it never had an issue only at the track then afterwards
Old Aug 24, 2013 | 09:01 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Let's see,
stock worn out bushings on the rear control arms,
stock weak flexing stock control arms
worn shocks
worn torque arm bushing
These will all give you traction problems considering they are all probably 20+ years old with who knows how much milage.
Being a 5 speed, you need to really practice launching, and getting the proper launch tpm for your car, of course if your trying to launch hard on a worn out suspension with hard street tires, your wasting your time.
Rebuild the suspension with good aftermarket parts and ad some sticky tires, and before you know it, it will be hooking so hard you'll bog instead of hop, and you'll be breaking t-5's before you know it.
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Scamo-2.8
May 20, 2016 07:01 PM
IroczFan
Oct 6, 2015 10:13 AM
dyeager535
Aug 28, 2015 08:10 AM
